well i got given 3 sheets of metal the other day (3 x 1000 x 1000) and ive been planning to make a case from scratch for a while now, ive got a few designs in mind that i want to try but since this is my first metal working project i thought id go with the simple one to start.
i wont bore you guys and girls with plans of the build, ill just do my best to build it
started out with 6 squares of metal 400 x 400 mm
welded them together to form a cube (no photos
but im sure you get the idea)
took the angle grinder to the front/top half to form a lid that will be hinges
then bevelled all the corners off
did the same thing with the lid piece to
so far it sits like this (lid is held in place with welding magnets in the photos)
this maybe a slow project though as the NAS needs to be start and Desk needs to be finished up before i get to carried away here, but as im waiting for weather for the desk i thought id make a start and see how i got on before starting the NAS. i was going to make some videos of this build progress but found my phone would only take about 8 mins of video before stopping :cussing: so i may need to look at getting a cheap action camera or something to do videos
