Sandybridge + Gpu :/
benj3
With the new sandybridge boards and the integrated gpu within them is it still possible to install a graphics card and use that as the main GPU unit? and if so will the gpu within the processor improve even if you have another card installed?
Its one or the other tbh. You just disable the onboard GPU and run a dedicated card. Unless you have a H67 motherboard you cant use the onboard anyways. Shouldnt say anything yet but meh.
Lol tom is gonna get introuble for the releasing info to us early, thats why i love this forum!!!
He wont:)
and you get integrated graphics with h67, but you do not get overclocking features of the k series, so you should take good care when buying a processor, are you planning to overclock? If you are buying a decent graphics card it is not very necessary to have integrated graphics. In my opinion, I think it is a waste of space on the chip which could be used for other functions. Does have it's uses though in smaller, day to day computers I agree though.
Wait are you trying to ask if you can use dedicated graphics with the CPU has integrated? If you are yes you can use a graphics card. it's like with i3 and how that has a built in GPU, if you put a graphics card on it will supersede the integrated one.
Thanks for the feedback guys
the new 2500k it is then!
These new MB's might make a nice HTPC. Would be nice to see someone build an HTPC and let us know how they do (wink-wink-nudge-nudge).
I know Tom's busy but maybe in a month or two when things slow down. I trust OC3D much more than others for honest info.
Ok so here is all i know about the sandybridge stuff:
Starting at the Core i3, there are NO onboard graphics at all and it is compatible with both the H67 and P67 Mobo.
The Core i5 2400 and 2400k, only difference being the k denotes unlocked, both have onboard graphics, but it is only usable with H67 mobos. the P67 board does not support the onboard graphics capabilities of the new CPU.
The Core i7 2500 and 2500k, same difference as the i5, are exactly the same, they have the same overclocking capabilities and all, no need to dwell on it.
Now here's the new part: SandyBridge actually has another division of Mobos that aren't in full production yet that are built more for gaming that actually do support the onboard capabilities and allows the CPU to be stretched to its absolute limit safely. It's the SandyBridge equivalent to the X58, its called the Z58. this is going to be the top of the top of the top for SandyBridge, but, like i said, these aren't even in full production yet.
As of now, for gaming, you should get an i7 2500k and a P67 mobo. For a HTPC, an i5 2400 with the H67 mobo, reason I say the 2400 and not the k is because overclocking isn't exactly necessary. This is what i have so far on my research of the CPU and Mobo.
there is no 2400k. there are 2500k and 2600k
Core i3 DOES have on board Graphics,
its called Z68 not Z58
there is no i7 2500k, its i5 2500k, i7 is 2600k
http://www.youtube.com/watch?v=wUgBNWtCsnk
NDA R BROKEN!
I'd hope it doesnt interfere, that woud kinda defeat the purpose of integrating it in the first place if it hinders performance, maybe you can set it to handle physx, that'd be tight.
