Samsung TV issue - New Gaming TV/Monitor Recommendation
CuttingEdge
Hey all,
So I am having this issue with my Samsung 55" QN95DTAAXU TV (I bought it in 2021/22) where while gaming the screen will go black for a moment as if it turned off and then comes back either right away or after 1-2 seconds. I've been using this TV as my monitor for last few months and I enjoy 55" realestate so much that no other 30+ inch screen can compete with But this flickering issue is just driving me mad. I had same thing on the 9070XT but there was some workaround with nvidias registry tweak disabling some overlay - that worked on the AMD card but it impacted performance. I had it from time to time on founders edition and now I have it again on Asus 5080. I have 2.1 HDMI cable as the TV only has HDMI ports and I ordered HDMI 2.2 cable which should arrive shortly. I turned off hardware acceleration in web browser / discord. I disable / enable HDR in windows. I lowered the refrash from 120hz to 119 to 100, to 75 and it still keep on happening. I have some small 24 spare monitor that I will plug to see if its cards fault. I even disabled IGPU in bios. DDU old drivers in with the latest version. I don't know if it's windows or tv is too old or what.. I used it with ps5 when it was sitting in the living room and never had such an issues like now. Input signal plus is enabled on all 4 HDMI ports in TVs settings.
Now I will be looking for a different screen if this is not resolved. This will be used purely as gaming screen (World of Warcraft 98% of the time - the rest is PUBG maybe BF6, COD and so on).
1) between 40-55" (nothing smaller)
2) gsync ?
3) probably not an OLED as I tend to go afk in game and it's just static screens - so burn in could be an issue
4) don't think I will like ultrawide
5) refresh rate not that important i guess
6) 800-1000 EURO budget
What can you recommend.
Yep cutting edge ''DO NOT'' get an OLED i am absolutely gutted with my LG G1 got so much burn in.
my mates samsung also had kick the bucket withing the 4 years he has had it now it will not even turn on so we are both looking to get something cheap and cheerful for gaming and viewing.
within that price range have a look at the HISENSE U7Q PRO 55" Mini LED 4K and before anyone go's of on but its just Chinese crap check out some of the reviews it is mini-led so dont have to worry about going afk it has 4 hdmi 2.1 ports and for 600 - 700 euro i think its a pretty good deal
couple reviews for you also there is another one here but im not sure its the same tv but it will go into the cons and well as the pros that the other reviews dont really mention.
currys has it for £699.00 for the 55''
