Samsung P2450H or Dell u2311H
It depends on what you want the monitor for tbh.
The Dell is btr if your wanting to do photo editing etc as it's and ips monitor and therefore not so good for gaming due to the 8ms response time, but the image quality will be much better ie btr colour recreation on screen, plus it's height adjustable, tilts and pivots which is always nice.
The Samsung is better for gaming or movies due to the 2ms response time, will give you great looking images on screen (for a tn panel) and it's cheaper.
But I know there are a lot of ppl on here who could go into more detail than I can, but like I said it really depends on what you'll be using the monitor for.
alot of people have gone with the samsung as it is a good screen
and out of the two its better for gaming
Thanks for the input, I will be using this for movies maybe a bit of web design. dont play games so will not need it for that.
The Samsung got a bad review on CNET and the DELL is a DELL, as was mentioned above. There are many dell monitor stands available on ebay. My guess is that the stands are the only things DELL makes that last... Find a third option.
if you are not gaming then go for the dell screen mate its a IPS panel so the picture quality will be better
