RTC Alarm on old PentiumD, No BIOS option available
J.Jdn
I am planning to use my old Pentium D 805 with Intel D101GGC as a downloader because my ISP provides free download period from 0200 to 0800. So i want my pc to turn on at 0200 if i leave the plug on.The product manual of D101GGC shows it support RTC Alarm from S5. But the BIOS (Phoenix - AwardBIOS v6.00PG) does not show any RTC Alarm option. I use windows xp. I tried googling about acpi settings on xp, but got nothing. Please guide me
damn download period where do you live nazi germany
Hmm.
I'm guessing the usual way to set this would be power options -> S5 and wakeup selection should be in a seperate list.
The only thing I can think of if they're hard to find/not there, is the bios version is more of an oem one that doesn't allow some changes. Some of them have "hidden menus", where you'd press ctrl+f1 and by magic extra options come up - this differs between manufacturers tho.
Look for a different bios version.
Hmm.
Not worked bro, any other ideas?
