Router Crashing!!!!
bbcake009
I have a Belkin G+mimo w/ 2 p.c. connected to it. One is wireless and the other is wired and both p.c. is playing on-line game (wow).... The problem is we both always get disconnected while playing wow, sometimes at the same time and sometimes not. Sometimes I see the router as if its doing its restart by itself....
ok heres the question... Is it better to get a router-n that is made for gaming on-line or should i get a router switch so that the wired p.c. can by-pass the router?
another thing, when does a router-n matters? does it matter on p.c. that is wired to it or only on wireless?
current spec: belkin G+mimo 54mbps w/ a high speed internet cable I think its cat5... its a road runner im not sure if u all familiar to it....
Any router will do and N will be for wireless and it's a mode.
Transfer rates are higher, I use a 120+MB router and see no difference in network speed with internet because my connection is 10mb. You will see difference when sending files over the network.
A gaming router is better for gaming ofcourse but there is no difference tbh.
Go for a Linksys.
