Dicehunter
Resident Newb
Always wanted to do my own ROG type build and now I finally can
The rig is almost done, Just need to neaten up the cables a bit more, 1 or 2 details here and there, A few cable combs and I'm done.
I took the SSD apart, Sanded down the metal shell, Painted it black, Baked it in the oven for just over an hour *This is a real thing
* and once it cooled I put some Carbon Fiber Di-Noc on to it as well as the HDD.
**Sorry about the picture quality my camera isn't the best**
Night Shot -
Top view -
Front view -
Changed the white rings on the SP fans from white to a nice matt black, I did try red but they looked very out of place with the whole build -
Cable combs came in yesterday, Decided to go with transparent -
24 Pin cable comb -
Installed an LED strip along the bottom under the mobo and under the right side of the mobo, No point installing at the top as it wouldn't be very visible and would clash with the white from the fans at the top and rear -
The carbon fiber covered SSD and HDD *Breather hole on the HDD is on the underside* -
Backplate for the Phoebus arrived and installed -
Little video showing the memory lights in action -
And another video showing the reboot process i.e the speed and theme -
Rig Specs -
Corsair H100i + 2 x SP 120mm Performance Editions In Push + 2 x AF 120mm White LED Quiet Editions In Pull
Core i7 4770K @ 4.80GHZ 1.34v *managed to get a nicely binned CPU
Asus Maximus VI Formula
Asus R9 290X Matrix Platinum
Avexir Blitz 1.1 Original 16GB 2500MHZ *Only a 100MHZ Overclock*
Asus Xonar Phoebus
Corsair Neutron GTX 240GB *Taken apart, Painted black and carbon fiber put over the top*
2TB Western Digital Caviar Black *Carbon fiber put over the top* + 4TB Western Digital Caviar Black *In the Rear*
Corsair 540 + 1 x 140mm AF White LED Quiet Edition *Rear* + 3 x AF 120mm White LED Quiet Edition *Front*
All braided cables are from Bitfenix.
Night Shot -
Top view -
Front view -
24 Pin cable comb -
Rig Specs -
Asus Xonar Phoebus
