Right so atm my rig has been the same since I got it from TTL customs. The spec list for it is as follows:
Lian-Li A-70B black with white powder coated interior
full water loop system with a triple rad
Asus P5Q-e motherboard with full water blocks
Intel e8400 overclocked to 4GHz with a D-TEK Fusion cpu block
2GB Corsair Dominator RAM 1066MHz
Gigabyte 4850 512MB RAM graphics card with a waterblock
2x Samsung Spinpoint F1 1TB hard drives
Gigabyte Odin 550watt pro psu
Got the rig back in 2009 and I just feel like its time that I update it as I got a laptop which is faster than it. All the older bits that are being removed from it will be going into a different case and used as a lan pc, this will strictly be a home use only pc. Probably will be getting the Fractal Design R3 for the old gear and mounting a 240 rad in the roof.
I've been using Intel for years but I feel like it's time for a change so I'm gonna jump ship to AMD
Probably will end up going for the 1100T black edition. Just wondering what sort of motherboard, RAM, PSU etc you guys would recommend.
Thanks Sal
Thanks Sal
