Review - XigmaTek XLF-F1253 120mm Fan
Watercoolinguk.co.uk
£6.94 Excl. VAT
(£7.98) Incl. VAT
Welcome to my first ever review!
Intro:
I recently bought this fan as a replacement for my exhaust fan for my Antec300 case. I had spotted
this fan on the WatercoolingUK website and decided that i will try my first review on this and see
how it goes.
I've listed as much information as i could possibly find, but if you require more please visit the XigmaTek website on www.XigmaTek.com.
The Packaging:
I placed my order for this fan on Sunday around 8pm and it arrived at 9am Tuesday morning using
royal mail first class delivery. As you can see the package came un-damaged.
The contents:
The contents of the package were 4 fan screws, a 4pin to 3pin power adapter and the 120mm fan. The
front of the package clearly explains the contents and specification of the fan inside. The dimensions
are clear and the website address is listed for other information and products supplied by the company.
Specifications:
120 x 120 x 25mm
1500rpm speed
67.5cfm airflow
22db noise level
longer life bearing design
brushless fan
Features:
Higher airflow, static pressure and torque
Reduction for noise and power consumption
Additional output functions available
Lowest noise level
Optimized blade design for higher airflow and better cooling performance
Installation:
For the installation i installed it in the front as it was much easier to illustrate and i could keep the
computer running at the same time. Installation was very straight forward with the usual four screws
holding the fan in place and 3pin power connector which is quite a long length for a fan of this size
and of course a welcome bonus. I replaced one of my original Xilence 120mm intake fans with
this to see if there were any noticeable differences. The results were my Hard-drive temps being
3*c lower and a considerable lower level of noise from the fan during operation. And for an added bonus
it looks cool aswell!
Final verdict:
When purchasing fans the factors i look for is performance without much noise and this delivers in mass
quantities. The orange blade, black surround and white led's add a nice touch of class and you get a nice
quality feel which is a rare thing in some makes and models. For the money this in my opinion is one of
the best value cooling fans which has arguabley good looks which appeal to gamers and enthusiasts alike
aswell as making a good addition to water cooling systems and radiators. Im extremely happy with results
and looks so it is definatley a recommended product!
£6.94 Excl. VAT
(£7.98) Incl. VAT
Intro:
how it goes.
The Packaging:
The contents:
Specifications:
120 x 120 x 25mm
1500rpm speed
67.5cfm airflow
22db noise level
brushless fan
Features:
Lowest noise level
Installation:
Final verdict:
