Review: ebuyer Slim ATX Case (Budget)
Sleekit
Never wrote a review before (probably due to the the fact my grammar, spelling and punctuation is awful!) anyway as much as I would have loved to write a review on a very expensive piece of hardware but I don't have the money do I thought id go the opposite way. As some of you know I was seeking a compact case for my old system, tried and failed many methods nothing ever seemed to suit. Then I found this case on ebuyer, I thought it looked amazing and it was only £17.99!
Sold.
Had nothing better to do so I thought id do this review for some practice and a bit of fun, so here it goes...
Specification (off ebuyer)
Case Size: 451(L)*149(W)*368(H)mm
Compatible with: ATX, MicroATX, FlexATX Motherboards
Expansion slots: 7
Drivespace: 5.25"x2, 3.5"x1
with one air-duct on left
Fan bay: 2 *6cm rear,1*8cm on right ,1*8cm left
Front 2*USB2.0+ 1 earphone jack+1 mic jack
Compatible with Standard ATX Power Supplies (PSU not included)
I didn't expect much packaging wise really, least they make it quite obvious whats in the box...
The rest was typical packaging you would see with any case
The instuctions that were included were very vauge haha, nevermind
Also included was plastic stands (ill stick to the fitted rubber ones) screws and 5.25" drive fittings
As some of you can tell this case looks amazing, very eye catching
The front of the case is all plastic, the middle and left hand part of the case are flaps to protect the DVD drives and on the right is a flap where you can add a card reader to (I didn't bother with adding DVD drives or card readers as this pc is intended just to play movies off the HDD to my tv).
The rest of the case is metal (not too sure what type, I don't know my metals haha) it's quite slim and bends really easily, just trying to punch out the expansion slots nearly ripped the case apart. The power button and the area surrounding it light up blue. Both sides of the case are toolless and can be removes by just pushing the latches.
The case inside is very compact as you have probably guessed, the psu has been moved from the top to the bottom right, an extension cable runs from the top to the front of the case to the bottom so the power lead can be plugged in at the normal place. I pushed out the extra slots on the I/O sheild plate and just used that haha (couldn't be bothered wrestling it out the old case) fits fine so im not complaining haha.
There is space for an 80mm fan on the motherboard tray, i'm not too sure if thats to intake air or to extract air from the PSU
Only space for one HDD, it fits in nicely at the top of the case
The fitted system, it was a bit fidgety to fit together as it was a compact space and not alot of room to move, bent a few capacitors etc. I couldn't do much with cable management as the case didn't have any haha, it's not too bad though.
The Good:
Small compact case
Looks great
Really cheap!
The Bad:
Flimsy metal
Cheaply built
Power cable just kinda slides into the extension cord, not really stirdy
Overall i'm really chuffed with the case, really cheap price and just what I was looking for, it was fun to put all together, sadly I can't use the USB ports on the front as my motherboard is too old to support it :(
You can buy this case on ebuyer
http://www.ebuyer.com/product/143896
I like it.
Definitely better than those HP Slimline cases which you can't seem to fit in any kind of PCI-e x16 card at all!
I think a modular PSU would suit this well.
I may actually buy one of these for a little rig i want to put together. Can you tell me something please, what the hell is that little compartment for above the mobo on the back? looks like an empty space to me...i reckon i could slap a 360 rad in there if i removed that....
Just read some reviews on ebuyer and yeah it is.
Only thing that puts me off is that it wont allow you to fit a full sized modern card eg. 3870x2 or similar due to the placing of the psu...thats a bit of a let down, has alot of potential but that one major downfall
WOOOP!!! 1000th POST!!!
Could you not move the PSU closer to the front of the case? Looks like theres some little spacers - if you got rid of them you could probably gain a good 2/3cm :)
also, It looks a bit strange for watercooling,. I dont think a gpu with a block on would fit in it tbh... Looks like it would be too wide. That spacer for the psu is the the adaptor to fit in. My PCA05B is like it...Even though i did actually destroy that bit of the case to make more room for a rad. I think i might buy this for a nice air cooled rig and stick to a low power gpu...Sod it...
Nice review. One could forgive the flimsy build quality when it has an £18 price tag. Also agree that the orientation of components are a bit odd, where the PSU placement is much like the PC-A05, as mentioned above.
Good point though I can't say that high end hardware and/or watercooling belongs in a case like this surely :)
name='zak4994' said:
Will a 8400GS fit in it?
My cousin is considering this as long as it will hold an 8400GS.
If he really wants to put an 8400 in there, it ought to fit. The card is only 17cm long:
Yeah you could fit that card inside it im sure, and yeah I didn't think of that other space being for another 3.5" haha
For me a few graphics cards would be an issue due to the cables coming from the PSU
