Removing the CPU from the Micro freezer
venusboy
All,
How long should the Prometeia be inactive before I remove the CPU from the Micro freezer?
Is there anything else I should be aware of?
Regards,
Tom.
Give it an hour and everything should be fine :)
If you have some tissue at hand in case theres some condensation under the hood, that might save a mini-panic :)
-> Welcome to EP :)
