M Memnok New member Dec 31, 2007 #1 Is there any apps that an remove/combine two partitions without reformatting? Freeware is always prefered! Thanks.
R realitybytes New member Dec 31, 2007 #2 Partition Magic will do the job although now owned by symantec you will only get a trial of it for free. Would be wise to backup any important data though changing partitons can go wrong very easy!
J jabski Banned Jan 1, 2008 #5 name='Toxcity' said: I swear you can do it with windows too. Click to expand... Not sure if you can in windows. Deffently cant merge partitions in windows
L Luigi New member Jan 1, 2008 #6 you can on vista cant you ? ive changed them in vista before, but not sure you can merge,..
T Toxcity New member Jan 1, 2008 #7 name='jabski' said: Not sure if you can in windows. Deffently cant merge partitions in windows Click to expand... You can "merge" them.. but only as long as it isn;t the OS partition. Did it with my server.
