So i got home and decided to attempt a small addon to my first case mod (toggle switch for my 120mm fan - i like my peace and quiet)
ithought that i would incorporate my other 2 case fans into the circuit so i could toggle between good performance but loud and bad performance but quiet. So i cut the wires and joined some (messy job with electrical tape) and decided to check if it was working.
so i grabed the 2 bare wires and held them against the fan socket on my mobo. All was well
the fans started spinning and i was ready to attach them to the switch. but my hand slipped, the wires touched, sparks flew and the comp turned off. (yes it was on lmao!!!!)
i smelt burning and saw smoke. i feared the worst. went to turn the comp on again and nothing. so i unplugged the power cable and turned it on again and it beeped then went off.
at least was an improvement. so i cleared CMOS, unplugged and replugged power cable again and turned on. it actually worked!! siting here typing for an hour with no probs!!
it is safe to say that io am recovering from a heart attack.... :anisx: :rotfl:
