Certainly. In my opinion (and down to my slightly limited experience, I only know two people with Gsync monitors) G sync only really makes sense/is noticeable if you're running a GPU that really struggles to hit the maximum refresh rate of your monitor (so think 4k with a 970). If you've got the GPU grunt to always max out the refresh rate of your monitor, all gsync will do is introduce some input lag.
In terms of games and screen tearing, all the games I previously had screen tearing issues now don't have tearing despite my FPS only dropping by 10 or so (we're talking running at a constant 240fps as opposed to 250fps). I play a few shooters that require reaction time (and low input lag) so I'd have gsync disabled for those games. The only game I've really played this year that I felt would have been improved by Gsync was Fallout 4 as the FPS in that game varies soo much depending on where you are in the map to the point where I have a few sessions of running the game on lower settings simply because some areas have too many shadows (or whatever).
Basically I feel that if you're a high FPS junkie (like me) or that you're running an OP setup GPU wise Gsync is simply a waste of money. I really like my monitor and I'd reccomend it to anyone, regardless of what GPUs they have.
even if I do have two dead pixels
Thanks a lot for all the information! Just to be sure, you're running an Nvidia GPU on a FreeSync monitor, right? I ask because you mentioned your turning off G-Sync for certain games. Also, what is OP? I know the abbreviation as Original Post or Original Poster.
I recognize I had an incorrect understanding about what G-Sync does, I'll read up on it in a bit, and I should rephrase my wish for a gaming monitor:
I'm looking for one that eliminates screen tearing (it was my belief that both FreeSync and G-Sync took care of this*)
and provides an awesome picture and stutter-free experience. Currently I'm on a cheap piece of, well you know what, out of necessity and in let's say GTA 5 and AC: Syndicate when I have Vsync off it's horrible, and only a bit better with it enabled. I'd like to alleviate it completely.
The ASUS MG279Q does look tempting, is IPS and 100,00 Euro cheaper than the G-Sync equivalent.
You're getting 240 FPS? If I want to run at a 144Hz refresh rate, can I or is it advised to slightly below that for optimal results?
I'm hoping some others with G-Sync and/or Nvidia GPUs on FreeSync monitors come in here as well - don't take this the wrong way at all!! I like multiple points of view on an expensive purchase is all.
* Hexus: “Having G-Sync enabled on a 27in, 2,560x1,440-resolution monitor makes a lot of sense for gamers who have a GeForce GTX 770/780-class of video card. These GPUs are able to mete out 40-60FPS in visually demanding titles and thus bring the visually smooth advantages of G-Sync very much into their wheelhouse. Once you see G-Sync in action and compare it against a traditional monitor there really is no going back.”
Overclockers Club: "
Playing through each of the games brought to light the kind of smoothness that only comes with this technology. It does not get rid of the game glitches that are part and parcel to the game in question, but does indeed offer improved visuals. You get the best of both worlds: no input lag and no screen tearing that you see when the frame rates outstrip the standard 60 and even 120Hz refresh rates of current monitor technology. As far as any performance hit, there really is no performance hit to speak of when enabling G-Sync technology.
By spending several hours in front of the ASUS ROG Swift PG278Q, what I did discover was that I found myself playing through the games much longer than I had before just because of how smooth the gameplay was."
PC Per: "But an interesting thing happened when enabling G-Sync. Not only did the tearing go away, but the constant stuttering was almost completely gone! This is an effect that I honestly did not expect to see, but it appears that something in the driver (or game pipeline) is adjusted or tweaked with G-Sync in play. The result is another incredibly smooth, fluid, and visually perfect game experience."
