Ready to order everything, Wht do u think about this ?
ANP !!!
Ok guys after soo much time of researching n all, I m finally ready to order my things :o
I m looking to order from Sidewindercomputers
n the list goes like this
D-Tek FuZion
Swiftech MCP655 pump
Swiftech MCW30 chipset block with new hard mount kit
Swiftech MCW60 GPU block with MC14s n MC21s heatsinks for RAM n Mosfet resp
Swiftech Micro-Res
Tygon #3603 1/2in ID 3/4OD 10feet
Total = 315.59 Shipped to my place via USPS 4-10 days
And all inside a CM stacker 810/STC-T01 :)
about the Rad Im still a bit confused on this part
BlackIce GTX360 from Sidewinders will be for 126$ Shipped, while a PA120.3 from Performance-pcs or MM will be for like 175$ Shipped, thats like 50$ difference.
My question is that is the PA120.3 really worth the extra 50$, the hassle to order from different store n pay extra custom charge for diff package being. (ie if i order everything from sidewinders i ll get a single package so i wont have to pay Custom duties multiple time :))
n do comment on the list of things i decided :D
TIA
ANP !!!
I cant really help you with what works best for water cooling. Instead i am in envy! I havent got that kinda money!
About the shipping though, if i were you i'd get it all from one store if possible. The import charges can sometimes amount to a very large sum. Besides one delivery date is something to look forward to instead of having to wait for a possible delay one one of the packages - therefore not being able to complete your setup.
:D
Post some pics when its all rigged up! Bet its gunna be purdy lookin'!
Hey thx for the reply bro,
I think ur right on this :)
btw just got a email from Gray, a BI GTX360 will be 126$ (inc shipping) more :) n not 133$
wht do u think guys ?
n i forgot to add i will be buying a CM Stacker 810/STC-T01 as well :)
Do Not Buy The Gtx360, The Pa Is Definitely Better. ANP! you know that :mad: 50 dollar difference? how???? I thought GTX was about 100 dollars, PA was 130 dollars or so.
GTX360 at sidewinders is 126$ shipped while the PA from performance-pcs is 172$-175$ shipped.. so thts pretty much it
anyways.. lol i have already decided to buy a PA120.3. man i cant convince myself in getting something that inst the best . :|
*sigh* we really should block links to imageshack and force people to use our upload server
Looking forward to seeing the loop finished
