Re-using CD-R 's
MarkW7
Is there a sort of 'hack' to reuse CD-R's.
I have ubuntu 8.10 on a cd i burnt and want to replace it with 9.04 without using another disk.
I also have some old files on a CD-R and i want to use the disk for gparted.
Mark.
Short answer: Nope.
Sometimes you can add to a CD if you havent closed the session, but as you more than likely wrote an ISO to the CD first time round it would have closed it for you I think.
I have never tried, but don't think so as the bootable disk needs to be finalized. Can't ubuntu install from USB stick?
