Rare problem?
wtf1337
Hello.
I am having some problem's:
CPU
Intel® Core™ i5-2500K
Motherboard
ASUS P8Z68-V PRO/GEN3
Graphics Card
Sapphire Radeon HD 5870 1GB
Memory
Kingston DDR3 HyperX 1600MHz 8GB
650w psu corsair
Os: windows 7 ultimate 64 bit.
One day after updating the bios i was going to bead and shutting down my rig and then the screen just go black? i can hear the hdd spin down but the fans are still going hard.
This hapens every time i shut down the computer, restart works fine.
What i have tryed: reinstalling, linux ubuntu works. but not windows.
It seems like it hapens after installing sp1?
Also tryed safe boot, another hdd. taking out the ram. gpu++
Can you guys help me?
Kind regards.
[font=Verdana, sans-serif, FreeSans]One day after updating the bios[/font]
I'd recommend clearing the CMOS on the board and having everything back to default settings and see if that solves the problem.
Sorry forgot to say that i have done that
But i was trying to revert to the old bios but the gui said that it was to old?
heh I can not even start my pc it just keeps rebooting the screen stays black and nothing works.....
aparently after clearing cmos and doing it agian it works but seriously this was annoying...
Just unplug the power supply for 60 - 90 seconds then plug it back in and everything should be fine. For some reason the fan controller software is still live in your ram even after shutdown. This worked for me.
Also disable PPL voltage in the BIOS it was one of the problems with the P67 P8P67 PRO as well and disabling PPL voltage solved it.
Sorry guys and girls.. for not doing an update.
I still having the problem after turinig off ppl.
Can you help me out here
What was the last thing you installed prior to this happening ? or is it just sp1 ? do you have sytem restore turned off as windows normally would create a system restore prior to updating... i would scan with maleware bytes but it does sound like a hardware issue, as the fan speed shouldn't change once you have a profile saved.
