RAID0 - How Do You Have Yours
Status
Not open for further replies.
jellybeard999
Im setting up my HDDs in RAID0 (Sammys in sig) and wondered - what cluster size etc is best to use / do u use
I want fast loading mainly... OS and games
What do u recommend ?
Any comparison charts for load times, transfer speeds etc ?
Thanks
Not worth it on a desktop machine, it's a i've got a faster car than yours senario.
You would be better of getting sata-2 hard drives as they would load games etc just of fast if not faster than on-board raid.
Proper RAID with SCSI disks is faster with dedicated controllers with on-board memory for data caching etc, on-board controllers are very poor imho.
Hope that sheds light on on-board raid, sorry if this is seen as a negative response.
Yeah, but i did have em raided at one point, and load times WERE faster...
Onboard controller etc.. BUT dont know how to set em up tbh... i just used defaults
No data is important on this machine, so i may as well do it...
Stick to Stripe on Optimum set-up (64k stripe size) although ifg you are video encoding they benefit for more and for benchmarking they benefit being 32k in size - 64k is the best for overall performance.
RAID is a great set-up to have - but is not essential.
Works especially well with 2x74GB Raptors ;)
Stripe is a very bad idea, because if one of the drives blows then you can wave goodbye to the other drives in your setup :(
I actually find RAID0 does really help loading times and file moving quite a bit, maybe its not RAID, but i CAN notice a difference, the files arent too important (have a diff rig for bakcups and important stuff - whihc is also put on DVD) - just games, OS and a bit of software... long and short - i have the pair of drives, i have the ability, files arent important, it goes faster - so why not raid ?
thanks for the help, ill go for 32kb now (on 64 atm) and see which i prefer - gotta format anywho - dual xp and 64 boot - both nlited :)
Yeah some peeps seem to think Raid 0 gives you a minimal performance increase, custom pc had an article on it a while back. From my experience (and benchies) the thing flies, windows is up in the time it takes that bar thingy to move across once :O I'll never look back from Raid 0 for the OS as for the important data just stick it on a non raided drive. Oh 32k stripe sizes on mine.
well 32k didnt want to work, so ive gone with 64k again 8)
anyway, i get 86mbs in SiSoft 05, which beats their 2 x 7.2k SATA150 HDDs so im happy :)
I'm just about to go RAID 0, well once i get a 2nd HD, hoping there is some going in the forsale bit of this forum, nearly enough posts to get there. I though you just plug em in and and as you instal windows xp you do the F6 option and wack in the flopy for raid drivers...
Status
