Radioactive or blackline?
Blackline, they look better and go with any setup. The radioactive are just as good but the bright yellow is a bit of a put off IMO. Depends what you like though.
Copperhead should be ok but i'd stay away from OCZ ram they have the highest failure rates and they don't make ram anymore so you wouldn't be able to get it rma'd.
The XMS are ok as well and that's a good price for 8GB
excellent price isn't it
My heart says mushkin but it's a £10 more at the very least for exact same performance. It' snot like I can see the RAM anyway and admire them lol
Corsair it is, but next time (a year) it will be DDR4 Mushkin time baybeh!!
EDIT http://www.aria.co.uk/Products/Comp...l+Desktop+-+CMX8GX3M2A1600C9+?productId=43431
which corsair is the newer do you think?
