Radiator suggestion
twisted5
I am looking to move my current wc setup to a seperate pc when I get back to the states and just cool my 7900gtxs and my chipset with water. As the cpu will be under phase. I am getting two nv-78s and the chipset block from Fragtek. I am looking at getting a D5 pump but wondering what people think about radiators. Would a HE 120.2 be enough or should I go with the 120.3? Or do you have any other suggestions?
name='XMS' said:
I'm running a BIX II and its very nice - compact too.
If you are pressed for cash , the BIX II is a great option. Otherwise my standard answer to the above question is PA 120.2 . HE series cannot perform well unless u slap on a loud and fast fan on it. I have an PA 120.3 with 3 enermax 120 mm fans at the slowest. Still keeps my x1900xt ( Heavily OC'd ) and my Opteron 146 nice and cool. Works wonders for me ! :worship:
I am leaning towards the PA 120.2 I'm not really worried about it being loud since it will be under phase so that won't be that quiet either. IMO if it is too loud just turn up the speakers :)
A few other lesser options, though easier on the pocket, would be the BIP series, MCR series, and possibly the Coolingworks Coolrad series.
