shambles1980
ok so my 240mm rad sprung a leak. (guess i must have knocked it doing a clean out)
i cant seem to find the hole. but the pump sure manages to get the water out of it..
If i could find the hole i would solder it. But as i cannot does any 1 know of something i can put in the rad or on the rad that will seal it up?
running on just a 120mm rad right now and at stock clocks managed to hit 80c after 2 hours of GTA 5 online..
So i would like to fix it up untill the replacement arrives.
i probably have an old pump some where i can use to circulate the stuff if needed (one that does not matter if it dies)
i also have some new tubing on order since a few days "its that time of the year" (re tube clean out replace the water and so on)
So i can re use the old tubing for the process..
any ideas welcome. but preferably none that will result in my pumps and block being full os crap after a month..
"I assume the only reall fix is to solder the repair. but like i said i simply cannot pinpoint the hole"
