P Poil New member Feb 4, 2008 #1 OK si ive got an opening on my sidepanel for a fan, should that fan Suck in or Blow out air ??? Is it supposed to suck in colder air to the cpu ? Or blow out the hot air from the cpu ??? got me kinda confused Thx for the awnser
B Bungral New member Feb 4, 2008 #2 Hiya.. the one on the side panel is mainly used for a fan on the inside to suck cool air in and blow it onto the gfx card / motherboard.
B Bungral New member Feb 5, 2008 #4 name='Poil' said: tyvm Click to expand... No problem and welcome to the forum.
M mrapoc New member Feb 5, 2008 #5 ITs up to you Try to have a good balance pf both but i'd have it blowing into the case
