I currently have a pretty swift system but its all stock voltages. I will watercool it when I have the time but I don't so I want to go just that little further. Currently, i'm at 3.0GHz but I would like to go further. Its rock solid even a sponsored 24 hour Gaming Marathon didn't make it get that hot. I have SLi with some 8800GTXs but the problem is my quad-core processor is now the limiting factor. I'd like some more pep to get the FPS up that little bit more (and my scores
) whether that be absolute speed (ok fsb x 9) or more bandwidth (high fsb x low multi). I assume that i need to change the voltage because I've whiled away many an hour working with stock voltages.
Here is my setup as of now, please be aware i have also had problems getting 1066MHz with my RAM at the stated 2.2V required by OCZ.
Hardware:
Windows XP Pro x64
Asus Striker Extreme 680i
Intel Core 2 Quad Q6600 3.0GHz (1333MHz - 333 x 9) G0 stepping
2Gb OCZ ReaperHPC PC2-8500 (930Mhz - 465MHz 5-5-5-15-2T)
2x 160Gb SATA2 Maxtor DiamondMax +10 (System Disk and Documents)
2x 320Gb SATA2 Maxtor DiamondMax +11 (Audio and Video)
2x Asus Extreme 8800GTX (600Mhz, 1000Mhz, 1406MHz) in SLi
Thermaltake 1200W PSU
Asus MW221u Monitor
Artic Cooling Freezer Pro 7
Coolermaster 4-in-3 Hard disk cooler
Drivers:
1503 BIOS
9.53 680i SLi Intel Edition
163.75 8800GTX driver
DirectX 9.0c
All Voltages: [Auto]
Results:
CSS VST @ 1680x1050 16x AA 16x AF - 318.11fps
3DMark06 @ defaults - 16069 - 6138 - 7513 - 4778
Hardware:
Windows XP Pro x64
Asus MW221u Monitor
Drivers:
1503 BIOS
DirectX 9.0c
Results:
