Pumps
Toxcity
A little question on pumps.
Can they run on there side.. or upside down?
I would have thought they could. :)
Thanks!
Sweet! :)
lol, I just put the case on the side.. and the water went foamy.. Needs a top up before I run it on its side..
Ill do it tomorrow!
Thanks again Ham!
get.php
Thats it. Its pyros, hope he dnt mind me posting it:D
you can just make sure that the pull of the pump is not inverted towards gravity. its not good for the pump over long periods of time.
i dont think DDC can, i recall reading it somewhere if DDC run upside down, the bit(not sure what to call that floating bit) inside the pump will keep hitting the case and cause damage.
you cannot have a DDC upside down, all other positions are OK though in terms of mechanics, although pushing upwards will reduce flow and pump life.
pretty sure there is a sheet with the DDC which shows you which are ok.
My ddc ultra can not be used upside down, says no in the manual but you can point the barbs down, sideways etc...
Which pump and we can be more specific!
Edit: Llwyd beat me.
Yip, can also confirm that DDC's cannot be run upside down, this is due to natural gravity pulling the impeller away from it's bearing/mount causing it to run to close to the top and sometime even foul on the top causing damage!
Any other Pump should be fine.. :)
