paulstung
I've just finished leek testing my loop, and all was fine, but when I connect the pump to the main psu, it won't start, it, kind off tries, but starts then stops, with my external psu, it works fine, on 5v, 7v, and 12v.
between the molex and sata, I'm using 4 ssd's 4 fans and the pump. I've even tried the pump on it's own, but still no dice.
The external psu is an XFX Pro750w, and the main is a Bitfenix Fury 550w. The specs are, Pentium G3258, Asus Z97 Gryphon, Sapphire R9 270x Toxic, 2 x 120mm, 1 x 140mm and 1 x 200mm fans, 4 ssd's and the pump.The pump is a Koolance PMP500.
