PSU cables
Dawelio
Active member
Hey guys,
So I'm thinking of getting an Corsair HX750i soon for my PC, as it fits well with my black & blue color theme.
My specs are (and hopefully soon), for you to get an idea over the colors of the components etc:
ASUS P8Z77-I Deluxe
Corsair Vengeance Pro Blue
Sapphire R9 290X Vapor-X (soon)
Corsair HX750i
Fractal Design Arc Mini R2
Although, I don't know which cables to get?...
http://www.performance-pcs.com/cablemod-c-series-axi-hxi-rm-cable-kit-black-blue.html
Something like this...
Or
Corsair's own sleeved cables...
I don't want to go overkill with it, I want it to be a "gentle" look so to speak, but yet appealing... so which ones would you personally go for and which ones would you recommend out of those 2?...
Thanks,
Chrazey
Hey guys,
ASUS P8Z77-I Deluxe
Corsair HX750i
Or
Thanks,
Chrazey
Well the CableMod would be cheaper than the Corsair ones, and CableMod cables are easier to bend than the Corsair ones, I can tell you the Corsair ones are hard to bend cause their only new but the CableMod doesn't have that problem
