Hi guys, (long post, apologies)
I've posted this elsewhere as to get a good range of opinions hopefully.
I'd really like some thoughts on what I've picked out, and if anything could be better, by all means post what you think could suit my needs better
First of all the use of my computer is effectively a custom spec'd workstation for 3d rendering:
ie decent processor speed, lots of ram and a fairly good gpu.
I'm a freelance CG lighting and matchmove artist, and I recently had a job which crippled my current machines so it's time for new bits n bobs.
Also I've been chucking computers together since around 1994, so I'm not scared to build them myself, although having one built somewhere is certainly appealing (my cable management was/is dire).
My BIGGEST conundrum is actually the cooling, and what to go for (water/air/both).
I need a fairly quiet computer as the machine is in my bedroom for now, and I sometimes have to leave the thing rendering for a week or two. So noise/heat etc. have always been a massive problem for me when I'm trying to sleep. (I'll be moving again soon so hopefully noise issue may subside for a while)
The last 'desktop' computer I built was quite some time ago now (2006), and I used a Zalman Reserator 1+. Despite all of the bitching I've read on other forums about it, I've not had 1 single problem with it and actually I even used it to help with a job a couple of weeks ago
Yes it's still working, I've not replaced a single thing except the water/coolant every now and then.
The main thing I love about it - very quiet, and works fine for the old parts.
The main thing I hate about it - physically huge, takes up too much room and I'm paranoid about all of the tubing.
So this is the main area I'm stuck with.
I'm going to give the old machine to my Dad, so it'll still be in service but I'm going to start from scratch, and I'm happy to use the latest watercooling or go with one of these huge air cooled fans like the Noctua NH-D14.
Budget - £1500ish it can go up more if I think the outcome will be worth it.
(since they get replaced every few years I don't like to go mental on a build)
These are the parts I've picked out, although I may use another company like scan or computerplanet etc to get a build as close as possible - potentially.
I definitely HAVE to overclock this sucker.
CPU = Intel Core i7 2600K
RAM = 16GB (4x4GB) Corsair Vengeance Blue DDR3 PC3-12800 (1600) CAS 9-9-9-24 ?
I actually would rather have 24Gb of RAM but I can't seem to find a deal on that.
OS HD 1 = SSD 120GB Corsair Force Sries 3
HD 2 = 3TB Western Digital WD30EZRX Caviar Green (or 2Tb caviar black)
PSU = Corsair TX850 V2 850W or Silverstone SST-ST75F-G Strider 750W
GPU = Nvidia 2GB MSI GeForce GTX 560 Ti Twin Frozr II/OC
Case = Corsair Carbide Series 500R/Fractal Design R3 or something else? (not into flashing lights and all that jazz )
CPU/GPU Cooling = Noctua NH-D14 or water cooled ?
Motherboard = Asus P8Z68-V or more likely Gigabyte GA-Z68XP-UD3P
Blu-ray writer = LG, 10x Blu-ray Writer (bog standard jobbie)
I think that's the lot right?
In the near future I'm likely to purchase 1 or 2 of those little cube machines based on the 2600k to help out with the rendering as well, at around £500ish or so it's worth it for what I do.
Many thanks !
Many thanks !
