Project Phenom
Psybadek
So currently im in the process of upgrading my pre-built HP. This will be a complete build and eventually be a custom one. This is one that will be done over time as I get the parts in for it.
Phase I: Complete
Graphics upgrade
EVGA GeForce GTX 650 1GB : http://www.newegg.com/Product/Produ...cm_sp=&AID=10440897&PID=3332167&SID=u00000181 Received
Phase II: Incomplete
Case upgrade
Cooler Master HAF 912 : http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Not Received
Corsair CX500M Modular PSU : http://www.newegg.com/Product/Product.aspx?Item=N82E16817139050
Not Received
Rosewill Internal Card Reader : http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
Not Received
Phase III: Incomplete
Almost there upgrade
Almost on the final phase
GSKill Sniper Series 8gb DDR3 Ram : http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
Not Received
Asus Blu Ray Drive : http://www.newegg.com/Product/Product.aspx?Item=N82E16827135247
Not Received
Phase IV: Incomplete
Final Stage Upgrade
This is the final and major phase. This is where I will be fully custom built.
MSI 970A-G46 : http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637 Not Received
AMD Phenom II X4 965 : http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Not Received
Samsung M7-7PD128BW 128gb SSD : http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
Not Received
I do have a 1TB HDD which will be formated and used as a data drive.
Cooler Master V8 CPU Heatsink/Fan : http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
Not Received
Windows 8 Professional x64 : http://www.newegg.com/Product/Product.aspx?Item=N82E16832416552
Not Received
This is the process in which I plan to upgrade my computer. This will take a moment to complete but I think it will be worth it. The final phase will be the longest obviously since it's the most costly and is basically what will make it a full fledged custom pc with the new mb and SSD drive. Looking forward to getting to it!
