Project PARVUM ARGENTUM - I need nand, lots of nand - Update 25/11/15
Hello everybody!
First time posting in this forum, been an accountless lurker for too long now. If you frequent other tech sites you may have seen me before though. I wanted to share with you all my new project, titled Argentum, a collaborative work with Parvum Systems!
I present to you, Project Parvum Argentum!
Brief:
A few months back, Justin of Parvum Systems approached me with a proposition. The idea was to create a wall mounted PC in a similar vein to my last project, Loramentum, but with monstrous hardware in mind. Seeing as Parvum did the machining for my last build, the thought of a collaboration project very much whetted my appetite.
So how is this going to differ from Loramentum? Well, scale mostly. This build is going to feature a lot of hardware, both on the cooling side and*in specs. In making this project larger, we also wanted to make some parts more daring. Whereas Loramentum features a simple 2 part clamshell design, we thought it would be interesting to increase that to three layers so that channels can pass over and under each other. What also differs is what stage I'm starting the log at. In Loramentum all the main renders were complete before embarking on the build. Owing to the number of manufacturers involved in this build, it seemed like that would be a tough call, so this time you'll be able to see the design evolve. I'll update the OP when the final renders for the project are completed so that they don't get lost.
I'd also like to give a big thank you to everybody who's decided to sponsor this project and to Justin at Parvum! *Without you guys this project could never have been possible.
Specs:
So what specs are we talking about here?
CPU: Intel Core i7 5960X
Motherboard: Asus X99E-WS (kindly supplied by Asus)
RAM: TBD (likely 64-128GB )
Graphics: 4(!) x Nvidia GTX Titan X (kindly supplied by Nvidia)
Storage: TBD
Power Supply: SuperFlower Leadex Platinum 2000W 8-Pack Edition (kindly supplied by SuperFlower)
Cooling:
4 x 480mm rads
4 x Laing D5
Aquacomputer Aquaero 6 for fan control
Rest is TBD
First Goodies:
Here are the first components to arrive:
First Renders:
The plan is to do a fully rendered version of the build, like I did for Loramentum. As such, I began to model the components that were sent, chiefly the PSU and motherboard. The following images were made using Autodesk Inventor and Blender (using Cycles to render the images).
Hello everybody!
Brief:
Specs:
Storage: TBD
Cooling:
4 x 480mm rads
4 x Laing D5
Rest is TBD
First Goodies:
First Renders:
