davido_labido
Well its time for another build!! This time I will be using the Phobya WaCoolT White OWL Case. This is a new case from Phobya so it will be interesting to see what I can do with it!
As per usual, I don't have much time with this build, it needs to be done before the end of August for I55!! Before we get cracking though, I do need to say a massive thank you to Pascal and Antony! A shout out to JR23 and Jamie too for help with the graphics side of things
So, without further to do, the case!!
This case was actually designed and made with help from the community, Phobya took the ideas and created this!
Now, it is a rather strange looking case i admit, and when i only saw the black version i wasnt too taken by it. Once i actually recieved the white one though, i much prefer it. Pictures dont do it justice tbh.
drive bays are far less common in cases lately as a lot of people have stopped using disk drives and the only real use for them are fan controllers. This case can hold up to 8 fans straight out of the box, so i will be using a decent fan controller (or two) to ensure they are all quiet, so im glad we have some bays!
The back of the case has 4 grommits for if you want to add any external water cooling, im not sure why you would need to as there is plenty of space in the case!!
speaking of inside the case:
As you can see, there is loads of room!!
there is space for HDDs just above the drive bays, this little hdd case is actually on rubber grommets to stop the drives from vibrating which is a nice little touch.
for watercooling i have a lot of options, down the bottom we have native support for a 360 or 420 rad
and in the top of the case we have support for 480 or lower rads, including 200mm rads!
and at the back, you could bang another 120mm if needed!
another nice addition is this nice little pump mount, again with rubber grommets to stop the vibration
So, thats the case! what do you guys think of it? A lot of people i have spoken to either love it or hate it, there is no real in between.
Im just waiting on some more hardware, and then we can get stuck into the build properly, i want to do quite a subtle build, lots of whites, greys and blacks, but I think I might add some orange, because.... davido_labido.
