Well I really like this forum, so as it seems I going to be sticking around I thought I'd show you a project I've been working on for a while. I decided I wanted a new case to house a water cooled system but i couldn't find one spacious enough, so I decided to try and build one from scratch.
I started out with some 1" angle aluminium
with a little help from a welder friend I had a cube. so I ground down the welds and ended up with this
this gave me the basic frame for my case, a masive 50cm square
