imported_Bazza
Here it is..............
Well, this summer is going to be long, and modding is set to be the cure..
This is based upon a Chieftec Dragon case, where everything will be made Matt Black, and have lots of Blue LEDs, in the fans and buttons, and lots of 4" and 12" CCs. Its going to be an Alphacool Watercooler COnroe Rig, using an E6600 CPU and the other bits havn't been decided yet...
SO, today, i got out the trusty Matt black Spray paint, primer and wet and dry paper...
I started off stripping the Fan Controller, so that its ready for painting...
The Metal bracket after painting ( 2 coats of Matt with 800 grit between)
With the Daughterboards in...
And with the aluminium fascia and platic bits...
I'm uploading the rest of the picceys for the other bits done.
AJ.
AJ.
