enRodjavel
Black N Blue Typhoon
"The new apartment killed it,... Rebornish"
So heya All, This is just my tired Build thats gona be getting a little Boost of performance over the next coming weeks.
First off all, the Rigg is now dead, my new apartment had some faulty wiring and this create a short circuit when I booted it up for the first time Today =/, A light smell of burned plastic and a tiny "puff" of smoke!
Atleast my fusebox's residual-current circuit breaker works xD, after taking everything apart and trouble shooting I'w found two soot spoots around the CPU-Socket and on the backside of the Southbrigde =/ the smell of burned plastic is getting more pungent.
The Motherboard won't start up at all, no Power, LED's dont light up, Fans won't start spinning and no boot-sound from the little PC-speaker.
After checking the MB and CPU (both Dead) I take a look at the GPU, this POOR sucker didnt suvive either =(.
Specs were:
MB: Asus M4A89GTD PRO/USB3 @ Beta Bios
CPU: Phenom II 1055t @ Stock
CPU Cooler: BeQuite! SR2
RAM: Corsair Value 8GB @ 1600MHz
GPU: Asus GTX 560 1GB @ Stock
PSU: Ocz ZT 750
SSD: 3x Kingston SSDNow300 120GB
Setup and Temporary Office.
My Keyboard and mouse.
Case window sideview.
Case open insideview.
Motherboard.
Backside of things. (yber-cablemanagment)
So now I'm left with a PSU that actually still works xD, Some DDR3 RAM and 3 Kingston SSDnow300 120GB drives (won one, got one from the Mrs. and bought one for 20$ and they are all the first GEN =D.)
I won't be using the PSU cause I don't truly know if it's in fully working condition after this event. I have 2 new in box psu's, 1 ocz zt 750 and 1 seasonic (ddon't remember the model nr but it's a 750W And atleast bronze)
Time for the small Boost in Performance:
Specs will Become:
MB: Gigabyte GA-990FXA-UD3 @ Beta Bios
CPU: FX 8320/8350 @ Stock as a starting point
RAM: Corsair XMS3 16GB @ 1333MHz (AMD stock settings)
GPU: SLI Gigabyte GTX 670 OC 2GB @ Stock as a starting point
PSU: Ocz ZT 750
Arrived:
MB: Gigabyte GA-990FXA-UD3 (27$)
GPU: 2x Gigabyte GTX 670 OC 2GB (120$ for the Pair)
Still Waiting on:
CPU: FX 8320/8350, Depending on which one runs the coolest (getting both, only paid 70$ for the pair)
RAM: Corsair Value 8GB (11$)
SLI Bridge, I forgot to take it with me from the old apartment xD
Alchemy white braided Cable extensions (orded a bunch for 20$)
Paracord in Blue and Grey +shrinkable tubing (50M of each, 20$)
Motherboard and GTX 670 SLi setup.
Just Cause.
So that's the beginning of the little Boost of Performance.
Updates will be coming as stuff arrives/gets found/gets here =D and ofc I have the time to upload...
//enRodjavel
Specs were:
PSU: Ocz ZT 750
Motherboard.
Specs will Become:
PSU: Ocz ZT 750
Arrived:
Still Waiting on:
Just Cause.
//enRodjavel
