Dawelio
Active member
Hey guys,
So I have a bit of an usual question for you, more towards you people with more than 1 monitor.
I have 2 monitors at the moment; an ASUS ROG PG348Q and an BengQ GW2406Z.
Now I have setted them up in Windows as such; The ASUS as the main monitor in the bottom and the BenQ on top of it.
Everything works fine like this, no complaints at all.
My issue that I'm experiencing is this; Whenever my monitors goes to sleep, and when I then wake them both up. This goes also for/if my PC decides to go into sleep mode (also regarding this, how can you turn this off? Since I didn't used to have this, that my PC goes into sleep mode. So that I just press a key and then it automatically starts again where I left off.).
Then when I wake it up again, everything is back to normal, except for everything that was on the top BenQ monitor now has jumped back down onto my main/ASUS monitor. I never had this issue before, only noticed it now when these 2.
For info I currently have Discord and Task manager open on the top monitor, which both decieds to jump down for some reason.
Any ideas or thoughts on how to make them stay put on the top monitor?
Thanks guys.
Thanks guys.
