Problems with Legion 1.5.0
fredtrix
Member
If you don't know what Legion 1.5.0 is; It's a h264 video encoder which let's you merge a video file and sound file from different formats into .mp4 etc. and still keep the quality high, it's especially good if you are working with uncompressed .avi files or PCM sound.
Anyway, my problem is that I can't get it to work. I've installed all the required programs and drivers which is needed and they are all the latest version. When I place the files I want to encode into "x" folder and start the .bat file all I get is the first step, I press "N" to move on and it says "Press any key to continue" then I shuts down and nothing happens.
If anyone knows what I'm talking about and could help I would very much appreciate it! Thank you.
i have this problem
I have this problem so what should i do? :( it used to work before but i dont know why it doesnt work now :( does this maybe have anything to do with 32 bit and 64 bit system coz i had 32 bit before or some codec missing?
