Problems getting Windows 8.1 working.
PortugaM
Recently i had a problem with my OS when i installed an update from windows update. After that i couldn't open anything, couldn't even access My Computer.
I was using windows 7 Ultimate, so i pick this issue to try the Windows 8, so i bought Windows 8.1 and installed in a SSD Raid 0. After installation, i tried installing Geforce Experience and Chrome, but my computer freezed two times.
After second restart my computer stopped showing any image on the screen...
My CPU is overclocked to 4.2 GHz using 1.075V, i tried using 1.08V, 1.085V to see if the system stop freezing, but now i don't have any image !
Please guys i need help with this.
Thank you in advance.
put your cpu back to stock settings first. If that doesn't work what has probably happened is that your Windows has installed the video drivers already and by you installing them again it probably has caused the driver to get corrupt.
Reset your hardware back to defaults and start there. If everything is stable at default clocks then start to slowly increase clocks/volts.
