You can get a 7970 for £400 if you look around and you can get an EK full cover block for £75. So, for £475 you can get the same thing, thats £125 cheaper than the LCS. Troll harder, Powercolor
Yeah i was thinking the same thing, £600 is hugely expensive. If it was my money i'd definitely avoid spending an extra £125 or so and spend it elsewhere. It does like pretty nice though, but its not worth an extra 125 quid.
If i remember EK even had a Acrylic block, that looks much nicer as well. The only bonus with getting this card is the fact that its garenteed, Where as using a waterblock on a normal 7970 will void your warrenty with some manufacturers. But still £125 for peice of mined is alot to swallow.
