Power supply Failure?
deathwish
recently i have been getting system restarts so i used pcwizzard to check the power supply rails
get.php
i have set the cpu to 1.35v in the bios
reading were taken not under load
do you think that the program is reading the values incorrectly, or the power supply's on its way out
Are you able to get your hands on a multimeter? even if you have to buy one, it's a worthwhile investment
As Raging has already pointed out the 12v rail does seem a little low.
If your PSU does blow up I wont be surprized as the Hiper 580w Modular units are well known for it.
Although mine is still going strong after 18 months.
had the psu for a long time so if it is it is on its way out then its no biggy
get.php
sandra is giveing me a warning too saying cpu is under powered :(
