The_Governour
Ok, this is driving me crazy... I have installed a new system and I can get into bios but as soon as I access my SSD and windows is booting up then it goes into Power Safe Mode and I get a black screen...... Read out number is AA.
BEFORE I installed the waterblocks etc then I tested the hardware and it worked - I even installed windows on my ssd with the drivers ffor the GPU etc.
Harware:
Asus x99 Strix
5820K
32gb RAM Trident Z 3200
Fury X with EK waterblock
AX760 psu
Kingston Savage Hyper X SSD
custom loop
Thermaltake Core P5.
24 pin + 8pin + 4pin on the Mobo.
The fury is conected through the Riser cable.
If it was the cable then I guess I would not even get into bios or get it to start o load windows or?
I have tried and take out the mobo battery, and I have reinstalled windows - all ok but then after 10 min then it goes into power safe mode AGAIN... and I stare at a black screen....
I have tried to dissable the power & sleep in the windows menu but it does not seem to work as after a time then it goes into Power Safe Mode again.
I am conected through DP - but the same DP cable then I have used with a previous system and it works perfectly, at least with the other system that I have here.
This is stressing me so much that I am about to throw the PC out the window... :ar:
WHAT can I do??? I need some help pls.........
Harware:
Asus x99 Strix
5820K
AX760 psu
custom loop
