Post rules first.
FFXIhealer
:mad:
You know, I get that private forums have rules. But having those rules posted during registration might help instead of admins casually deleting posts that aren't offensive in any way and are just genuinely asking for advice about a project from more experienced people. I took pictures of my post from my Google Chrome cache as evidence that I DID have a post, but now it's gone. No message was given as to why it was deleted. This isn't exactly the best way to invite new people to the forum, you know.
I have a computer from 2010 that I'd like to "complete" by rebuilding it into a water cooling system. And I was asking for advice about doing parallel GPU cooling, what tubing to use, maybe different CPU blocks or pumps in order to reduce costs, that sort of thing. I also intend to overclock the CPU and the GPUs once the loop is installed and working properly with no leaks. I even put the post under Liquid-Cooling. It seemed the correct spot for it to go.
Nope. Apparently, something's wrong with the post because it's gone.
By the way, Hi. I'm new here (obviously).
Just click on the FAQ? It's under the OC3D Forum tag. You probably broke a rule including pictures, etc or someone marked your posts as Spam. You'd be surprised how much spam we get. Not much a reason to be mad.
When it comes to watercooling money shouldn't be the #1 concern. It's expensive and no getting around that. AFAIK serial loops are more simple and therefore cheaper. If that is along the side of your question then that's my answer. I haven't done much watercooling in a while so i'm out of the loop(pun intended)
Also hi. I'm not new here... I feel old.
:mad:
Hey welcome to the OC3D forums.
Your post hasn't been deleted fella, it's just that you're new and your post contains links which have to be moderated I have now cleared it for you.
