Hi Guys :wavey:
Looking for a bit of advice / 2nd opinions here...
I'm going to uni late September and I'm thinking of building a 2nd PC at some point, to save me lugging mine between halls and home, and I despise laptops
I'm cut between 2 builds - a cheap AMD one where I can bring my RAM and graphics card home with me and get cheap 512 for my home one, OR a C2D build :yumyum:. C2D would make sense to me as it would be a ideal situation to move up to it!
I've been pricing up bits and pieces and have come up with this:
Asus P5N-E SLI NF650i SLi - £70.62
E6750 - £115.01
OR
4300 - £67.55
with either
OCZ DDR2 PC6400, Spec Ops - £64.00
OR
OCZ DDR2 PC6400, Reaper HPC - £79.00
WD 160Gb SATA2 8MB - £29.95
So the 4300 with the Spec Ops kit would cost £266.17,
whereas the E6750 with Reaper Kit would cost £328.63.
I'm really not sure of C2D stuff tbh and I'm wondering, is that mobo any good? Can anyone predict what kind of overclock I'd expect from the two builds on air? Also, I need something to power all this, after that thread about no need for <500 PSUs, can anyone suggest a PSU with enough power and at a good price? Bear in mind I'm not looking to spend as much cash as possible here, I'm looking for value!
I'll then be getting a 22" tft for ~£160, with these speakers, and this TV card.
Also - If XMS sees this - I'm wondering if that case is still available?
Cheers in advance guys
E6750 - £115.01
OR
4300 - £67.55
with either
OR
