M masterofinsanity New member Feb 18, 2009 #1 Hi, is there a way i can plug my xbox360 into my pc? is there a card i can get to do this or anything usb?
T Talonaer New member Feb 18, 2009 #2 get a VGA cable for the xbox and switch it with you pc cable on the back on your monitor whe nyou want to use it...
T Talonaer New member Feb 18, 2009 #3 http://www.amazon.co.uk/Xbox-360-High-Definition-Cable/dp/B000AYYADE
T Talonaer New member Feb 18, 2009 #4 and one of these if you want to make your life easier: http://www.amazon.co.uk/Port-Way-VGA-Monitor-Switch/dp/B000J249JC/ref=pd_sim_vg_h__6
T Talonaer New member Feb 18, 2009 #6 having some major line faults atm so my net drops off at the drop of a hat so really couldnt be arsed faffing at the time. sorry
M masterofinsanity New member Feb 19, 2009 #7 thanks for the replies, might get one of them cables for the time being til i can afford a tv.cheers
