L Luigi New member Aug 27, 2008 #1 Myn arrived today, and boy do they look nice. Unfortunately my feser 3/8" tubing has got one of them stuck to a barb, even with the clamp undone I havent managed to pull it off Anyway, here are the images: Someone in the UK really needs to stock these What do you guys think?
J JN New member Aug 27, 2008 #2 Whoa they are huuuuuge! Its almost like what I use on my hosepipe in the garden
K k4p84 New member Aug 27, 2008 #3 Never been a fan of compression fittings personally but those do look good
L Luigi New member Aug 27, 2008 #4 They're not compression You use normal barbs, then these are the clamps.. Im going to get some descent pics of the later with my dads SLR
M Marcus New member Aug 27, 2008 #5 They look scratched? I first saw these on Orac, had a bit of a softspot for them ever since. Looked at importing 100 over but the price at the time was crazy so didn't bother. How much they set you back?
D Daza New member Aug 27, 2008 #6 Way the photo is taken + flash. Now get back to work with the forums.
K k4p84 New member Aug 27, 2008 #8 name='teknokid' said: They're not compression Click to expand... My bad Well if its stuck on you could be fairly sure you won't get a leak
L Luigi New member Aug 27, 2008 #9 name='k4p84' said: My bad Well if its stuck on you could be fairly sure you won't get a leak Click to expand... Haha You can. I got myn off someone brand new who had a few spare on bit-tech. Cost me a fiver each, not horrific. You can get them from here http://www.usaimports.co.uk/index.html in the UK, although the site doesnt look that great.
L Luigi New member Aug 27, 2008 #11 some better images, although Im finding them a PITA to photograph with flash Ill wait till I have some better light...
K k4p84 New member Aug 27, 2008 #12 yer, flash and shiny things = tricky. You need to up the ambient lighting not a direct light source like a flash. Snapping outside is good though the UK outside came be fairly dark too
L Luigi New member Aug 27, 2008 #13 name='k4p84' said: yer, flash and shiny things = tricky. You need to up the ambient lighting not a direct light source like a flash. Snapping outside is good though the UK outside came be fairly dark too Click to expand... Yeah, Its too dark today, Ive tried the flash gun on wireless, and having it to the side, but still mixed results
K k4p84 New member Aug 27, 2008 #14 its still a flash light source. try using a lamp with a bare bulb, a nice eco unfriendly 100W take the flash off the slr and snap away ED
