Phobya G-Changer 360 build quality???
leejc73
Hi guys it's tiny.......no hold on a minute it's not at all.
Back to topic.
Has anyone bought a Phobya rad recently?
What's the build quality like??
Reason I ask is the screw distance width ways on my G-Changer 360 1.2 is off by about 4 mm's (to long), it's made getting it mounted in the haf-x a nightmare. On closer inspection it looks like the fins have shifted on one side as well. I'll post pics later.
I did wonder if it was the case but the Xspc RS (thin one) 360 I just took out fitted perfectly.
Cheers
Lee
