B blair New member Jun 7, 2011 #1 Hi, Whats the max voltage you can safely put into a Phenom 8400. Thanks
G General_Chris New member Jun 7, 2011 #2 you can look at amd's website to find the max safe voltage for your processor
B blair New member Jun 8, 2011 #3 yes but the amd site says 1.4v for a 6 core but everyone says 1.55v and for this cpu it says 1.25 which is the normal voltage anyway so you mean to tell me i cant OC this chip as i have no more voltage head room?
G General_Chris New member Jun 8, 2011 #4 well you should be fine if you keep under 1.4v watch your tempratures also
dugdiamond New member Jun 8, 2011 #5 here are the top speeds for the 8400 X3 via HWBOT http://www.hwbot.org/image/451513
