Hi guys, :wavey:
I've been having issues with my PC for a while now and if I had some spare cash I'd jack it all in and get new gear but unfortunately I don't have the funds to burn :flames:
Here's my rig specs:
CPU - Opteron 146 @ 2.6GHZ atm
Motherboard - Abit AT8 32x Mobo (provided for free by OC3D )
Memory - G.Skill 2GB DDR HZ PC4000 (2x1GB)
Cooling - Silverstone NT06 CPU cooler. 2 x Coolermaster 80mm fans.
Power Supply - Tagan 530W PSU (XMS' leftovers)
The problem I have been having is this - My PC never starts up first time. My usual bootup consists of this (takes a deep breath):
This has been the case for some time. I've changed ram, left it all at stock, cleared CMOS, rebuilt the PC and tried a different bios battery. Problem still occurs.
I RMA'd my ram due to memory errors and I got a nice new kit last night
. Tired after work I went to fiddle with my pc, my side case fan was in a link to the HS fan and as I disconnected this I disconnected the HS fan
. I didn't notice this right away and the PC beeped at me, but I thought it was due to the ram and tried 3 different combinations, PC not being left on for longer than 5 seconds at a time.
I realised it was the fan and I reconnected it all but it wouldnt post no matter what
. I reseated the CPU and HS last night but it still won't post. Has my CPU been fried after this short a time? I thought the HS could cool it passively for this short period anyway?
Is there anything you guys can suggest to get it to post? I'm quite prepared to buy a new motherboard as I've never got on with this one tbh, but I'm wondering if I should buy a new CPU at the same time? I'm also wondering about the PSU, but I'm hoping it's not this as it's a decent little Tagan.
Thanks in advance for your help :beerchug:
- Press power button - Fans start and then PC goes straight off.
- Press power button - Fans run, no post.
- Press reset button - Fans start and then goes straight off.
- Power off, back on - fans run and it posts. But it is in fail safe mode and has unclocked itself.
- Reclock and requires another set of reboots to get going
