pc power&cooling deluxe 510
i read a review on them...
they got adjustable rails for all lines...
thats good...and they are 610W arent they?
i wont be getting one over my enermax though cos the enermax gives better lines on the +5 and +3 iirc without tweaking the pc power and cooling psu.
well i couldnt justify selling my 550W enermax for one of them...
i would defo consider one if i never had bought the enermax ;)
I've got one on order. Look very good from what I've read. Adjustable rails, good warranty and good overall quality. Something like a 650w peak output.
Had an Enermax on order but decided to cancel for it.
only thing that is putting me off a bit is the noise, its noisier than tagan supplies (yes I am obsessed with silence !).
Hi guys, from what I am aware there are two flavours of the 510 Deluxe PSU. One of them has pre-modified silent fans - I've ordered both types but I have yet to hear back from them relating the specifics. I will make a concerted effort on Monday to get in touch with them and find out.
I spoke to them the other day - it's a no go for the silent fans basically. You can use quieter fans but they dont recommend it for obvious reasons. What they did say however, is that these fans are auto-sensing, so if you have good case temps and good load temps the fans wont be on 100% permamently.
