PC acting weird
Dawelio
Active member
Heya,
So I turned on my PC today after been working during the weekend... all went fine, and it started doing the slow windows booting again (worked just like normal, normal fast boot after first initial boot after build).
And then all of a sudden, when looking on Facebook friends list, the screen just went dark and got "No signal detected" on both monitors and then the PC restarded out of no where. Once in Windows, the wallpaper was all black and no menu bar.
Used the reset button to retart it... and now Chrome keeps crashing randomly for some reason.
Maybe a fresh Windows install is in place or what do you guys think?.
Thanks,
Chrazey
Are you on W10? Might want to try to see if there are updated drivers available for your 980Ti on your OS. If that would fail and you aren't on 10 yet, you could try a fresh install. (I do recommend a clean install and no upgrade to avoid any bugs)
We need a few more details in order to help. Such as OS, if you tried a different browser, gpu drivers etc..
Sorry lads, keep forgetting that information...
As far as I know, internet explorer works fine, haven't tested it extensively enough to know though.
I'm on Windows 8.1 64 bit as well. GPU drivers I'd have to get back at you on, as not on my PC at the moment.
