Mr. Smith
Silence is golden...
I was thinking of getting the pa120.3 and getting some nice quiet fans on there... £60ish plus p&p and 3 decent fans (approx £10x3) = £100ish
Then I saw the Alphacool Mo-Ra 2 Pro for £105... I think its passive (although Scan state the Fan Screen is required, specialtech don't?) which also came in at £105 (plus the £25 for the fan shroud if it is required)
From what I can gather the mo-ra is a bit of a flow killer but does it perform well temp wise?
I was thinking about the Alphacool Cape CORA too but that is alu and my blocks are copper... So maybe that would be bad?
Everyone seems to bum the pa120.3 hard - is it really that good? I want my new rig to be barely audible so I can f@h 24/7 (and I just want it quiet) as my pc is in my room.
Unrelated: Don't like my li-li case. Waaaay too big for my taste. Going to clean it up back to 'as new' and decide what to do - sell or keep. T'was £82 delivered although it will house the pa120.3...
Anyway. Passive setups/uber quiet fans... Whatcha think to the above?
