my friend has a pd 940, a Asus P5LD2 Deluxe motherboard, and a Scythe infinity
the infinity's mounting holes should connect with the LGA775 4 holes. should just pop in
this is where the problem is. the backplate on the motherboard doesn't allow the infinity's mounting tabs to go all the way through, since when the tab goes through the motherboard, it doesnt go through the backplate which is much smaller holes and looks like you have to screw it in
question is, can this backplate be removed? he said he tried as hard as he could but he couldnt rip it off, and if he tried harder the mobo would have snapped.
any ideas would be amazing! i was thinking of getting a hair dryer and heating it up alot, and then trying to remove it. other ideas are welcome
